Discuss plumber has not fitted water supply pipes level to tiles in shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
plumber has not fitted water supply pipes level to tiles in shower, one side is approx 5-7 mm out of line, can i fit some sort of extension to resolve?
Cranked S unions for showers should sort it. They are 1/2” one end to, fit into what you have there, and 3/4” the other end - to which you can attach any bar valve.
The cranked nature allows you to level up incorrect pipe heights or spacing.
Reply to plumber has not fitted water supply pipes level to tiles in shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Hi All, Looking for some advice on my little bathroom project. I took the bath out. I got a shower jacuzzi thing. The base has 2 wheels in the...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
