Discuss Plumber or Electrician - Newly fitted valve faulty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm just looking for some advice. I've just had my 3 port valve replaced. A simple replacement of like for like. The old one had been working fine since I moved into the property 2 years ago but was old and died last week. My local plumber replaced it for me. The new valve isn't automatically sending the hot water to the cylinder. If I manually switch the valve it works fine. From this i have guessed its the wiring. However, when i asked the plumber who fitted it last week to come over and take a look he is refusing to, sayings its an electrical job. Am i expecting too much of him to come and look at his own wiring?
its quite possible your old valve was ok and the faulty component is still at fault possibly a thermostat
I’d find a better plumber. Lots of sparkys claim to understand boiler wiring and Dont. Lots not all I hasten to add
Diagnosing the fault my be simple, but get them to drain a 26 radiator system to change a complete zone/mid valve.... then they’ll play dumb and get a plumber.
I don't touch water! That's for plumbers!
Not an unreasonable expectation, but he's probably used to getting people claim it worked perfectly until he changed the valve and thinks you're scamming him.
Always difficult to prove to the customer it’s been diagnosed correctly
Has he fitted it the right way around?
He should have tested it before he left, if something else has failed then it's still s plumbers job not a sparks. If he's willing to change motorised valves he should be at least competent to test/ fault find on the controls as well otherwise how would he know the valve was faulty in the first place.
The 3-port valves I'm familiar with are spring return to the HW position. So if it's getting no power it should be sending the hot water to the cylinder. Sounds like a wiring issue. Diagrams are available on the internet (if not in the box the valve came in) so you could do a prelim check if you feel competent.
Reply to Plumber or Electrician - Newly fitted valve faulty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am looking to join a plumbing and heating engineer 4 days a week whilst I attend College to gain my level 3 plumbing and heating qualifications. if...
Billy Barnard
B
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
