Discuss Plume management for external grant oil fired boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pipholt
My neighbour is complaining about the steam coming from the boiler, even though it is permitted distance away from her house etc. Does anyone know of anything I can fit to the flue to direct the steam upwards that won't cost the earth?
Many thanks
You're best off contacting Grant. They do a lot of different flue options and will definitely have something that will do the trick, don't know about cost though.
Mike
Thanks Mike. Have contacted grant and they do have something but coming in at just under 300 inc VAT. Was hoping to spend a little less to keep my neighbour happy!
Unfortunately your stuck with using the manufacturers own flue systems. The only other way is to put a screen up ensuring you comply with the minimum clearances.
Mike
This is becoming more of a comon problem, I hear there may be changes on the way to counter this.
Reply to Plume management for external grant oil fired boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, is it ok to turn on and use new grants external oil combi boiler, before it gets commisioned next week ? or can this cause any damage at all...
Hello. I'm hoping to get some advice. I moved into a new build house a few years ago. A Firebird Silverpac external oil boiler (kabin pak type)...
1K
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the...
1K
Hello everyone. The flue from my glowworm CXi boiler sticks out the side wall of our house in front of the kitchen window. It's around a metre...
2K
Hi all I have to site a condensing oil boiler close to a boundary. Its going to be one of these Greenstar 50/70 or there abouts. The 600mm rule...
1K
