Discuss Polyfit pipe fittings? in the USA area at PlumbersForums.net
macka09
Hi guys. Do any of you know whether the grey poly plumb fitting and inserts can be used the white polyfit pipe? Can’t seem to find a local stockist of the older white polyfit fittings.
Ideally you want to keep it all the same, due to slight differences in pipe thickness.
But, you get away with swapping the pipe between the two. Obviously you can’t use one brand fitting another brand insert.
But like anything, you will increase the risk of a potential leak.
Can’t you order the fittings online?
Yes your fine just use the stainless inserts
Cheers chaps. It’s not one of my jobs to be honest. I called in on a mate and helped out for a couple of hours and noticed he’s picked up polyplumb fittings but I didn’t see the inserts he had. I just wanted to advise so he don’t get caught out.
Reply to Polyfit pipe fittings? in the USA area at PlumbersForums.net
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
C
Hi there, i’m in the process of remodelling a new build home and have a towel radiator i will be fitting soon to replace an ugly traditional...
1K
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
