Discuss Pool room boiler powerflush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Harvest Fields
Subscribed
Morning all. Hopefully somebody knows the answer to this. But all I can Find is that you have to have a special qualification to work on the gas side. Does anybody know where I would stand power flushing a radiator circuit on a boiler that also heats a private swimming pool in a domestic property?
Many thanks in advance
Is it a swimming pool boiler or a standard boiler?
From what I can gather you are fine to carry on as normal as long as it's not a specific swimming pool boiler
I thought that, but was not sure. I would only be on the plumbing side anyway and not the gas.
Cut into the flow and return, or if you want to flush the boiler as well both into the return
And just flush upto the plate heat exchanger
Was thinking I would take out the pump? Or is that a bad idea? The pump is on normal size pump connectors.
Reply to Pool room boiler powerflush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
