Discuss power flush on a oil fired combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi fellas,
have a power flush lined up for later this week - use a Fernox machine and have done quite a few in the past but never on a combi boiler. This boiler is a Warmflow Kabin Pak system boiler with the twin head pump. I would normally attach the power flush machine to the pump valves but not sure about this one? Any help much appreciated,
cheers
dave
I would disconnect the primaries off the boiler, and link in there, best not to fill plate ex with crud imho.
thanks Jonny and lame for replies - in the end I kind of chickened out.... I left the power flush machine at home and just manually flushed by removing a couple of the rads downstairs and running mains thro the system - seemed to work a treat! maybe there is too much hype surrounding these power flush machines..
Reply to power flush on a oil fired combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered...
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the...
