Discuss Pre-heat for Unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Certainly the drawing and labeling are incomplete with regard to temp / pressure controls etc. Which could lead to persons mimicking these designs in the real world. altering the balanced cold would be the least of your worries.
if your buying a 2nd solar cylinder why not replace the original one anyway and have a more effective and less ***bersome sytem, seems like another bright idea jumping on the bandwagon for flogging to the general public, then running away.
Reply to Pre-heat for Unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
