Discuss pressure loss on sealed system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bigbeak07
im totally stuck with a central heating system i installed last may. everything was working fine until last dec when i got a fone call from the customer claiming that the pressure on her boiler had dropped to zero. the boiler itself is a worcester 40 cdi and was fitted onto an existing open vent system. The house is very large and over all has 9 large old double panelled radiators, without the convector fins. my immediate instinct was a small leak so i checked all the new trv and lockshield valves i had fitted for leakage and added a dose of fernox leak sealer. after a few days i got another fone call to say that the pressure had dropped again. i went back and checked the prv and expansion vessel, they were all fine, next i started to zone off the upstairs circuit from the downstairs and left this for a day to find the pressure staying up. since then i've had all the downstairs pipework (which is all copper with yorkshie fittings) exposed and have not managed to trace any weeps at all.
Could the explantion for the pressure loss be due to the expansion vessel on the boiler being too small and needing an extra one fitted?
:confused:
ive ran the boiler to correct running temperature and pressure is rising to correct 4% increase.(no overpressurising)
Ive considered repiping the downstairs circuit although the customer cannot see the point if a leak cannot be found.
everyones ideas wud b much appreciated! many thanks
Reply to pressure loss on sealed system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
