Discuss Primus 2000 Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
simrun255
I have a couple of propane cylinders at home full. A mate of mine suggested i get a primus 2000 cylinder and use that and when the gas runs out refill it using the propane calor gas bottles i have at home. Has anyone had any experience of refilling their own bottles.
I have never done this AND WOULD HIGHLY RECOMMEND THAT YOU DON`T TRY IT EITHER...regards turnpin:hand:
Just take the propane cylinders with you and do your soldering the old way!
It is really quite easy to do but do it at your own risk. It is not recommended.
Reply to Primus 2000 Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the...
Hi, Just after some advice please. I have a small outdoor gas pizza oven with the below connector. I also have the below connector (and...
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
