Discuss Problems with small bore pipe and an old central heating system in the Central Heating Forum area at PlumbersForums.net
74EBAB47-FAFD-42A8-BF81-C0002730141B.jpeg9F1955B3-7603-4E16-8E22-80E2D164D5C5.jpegA5B882F5-C0C6-4278-AAC5-1CB028734A15.jpeg
Update. Central heating has now been running ok for the last few weeks with X800. Every few days I have been cleaning out the two magnacleans I installed. Last time was today after I left heating on timed (one hour in the morning and one hour in the evening) for the last 8 days. It collected magnetite as per the photos attached. Should I leave the X800 in for a few more weeks until it collects no more magnetite or drain and fill with inhibitor now ? Many thanks.
Update. Now into December and with the X800 still in system I continue to collect weekly amounts of magnetite. See pictures. When is the right time to drain the system and add x100 ? Many thanks.
Update (October 2023). System still running perfectly. I drained down in the summer and put new inhibitor in. Recently powered up and the central heating is running well. Still collecting the debris in the 2 magnacleans I fitted at the troublesome spots on the system (entry into the small bore pipes leading to the radiators that did not heat up) but I dont mind cleaning them out every month. Rather this than spend £2k on a power flush that is not guaranteed to work and may cause no end of problems on my 40 year old multi pipe (normal and small bore) system! Learnt a lot on this forum and if I had my time again would not have allowed these so called 'professional plumbers' to install small bore pipes in my system!! Thanks again. Cheers.
Reply to Problems with small bore pipe and an old central heating system in the Central Heating Forum area at PlumbersForums.net
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
I need to extend my central heating from my newly built extension in to the old part of my house. I need to feed 3 rads in separate bedrooms on...
