Discuss PRV on sealed heating in the USA area at PlumbersForums.net
Just wondering if I can put the sealed heating pressure relief valve on the hot water return? As I can’t get relief pipe out where boiler and controls are
[automerge]1604061267[/automerge]
just to add is an open vented conversion
No as it needs to be on the primary’s as the port valves could be closed
Reply to PRV on sealed heating in the USA area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
