Discuss pump advice for a gravity fed system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
fishhead
Hi all,
Please can i have some expert advice. I have a gravity fed system and i've just bought a lovely mira digital low pressure shower system that comes with a pump specifically for gravity fed systems. This pump will just provide pumped water to the shower.
As i'm also in the process of re-modelling my bathroom i'd like some new bath valves/taps and a bath waste filler. All the ones are like are not compatible with low pressure systems so i'd like to buy a separate pump to feed the bath and sink.
How do i configure the pipe work so that i can have 2 pumps without either one affecting the other?
i'm happy to run a separate cold feed from the tank in the loft to the shower pump but what about the hot?
do i need to use non return valves and if so where?
I hope this is clear. Any help or steer would be greatly received.
Thank you
Yes I have two large tanks which are linked in the loft.
Thank you
From the Header tank to the vented hot water cylinder to give added pressure to the system. for domestic hot water to taps.
Fishhead:
Why, if you are refurbing the bathroom, are you using taps that aren't suited to low pressure and then fitting a pump? Would it not make more sense to use taps that ARE suited to what you have?
Thank you so much for such clear concise advice. This makes sense thank you.
Ric2013. All the taps I like only seem to be compatible with high pressure systems (not gravity fed) so if I put a pump in this will give the high pressure I need - will it? Surely a pump is the best way to go? I'm very open to advice as I'm a novice. Thank you
Personally I would keep looking for taps, not sure the noise of a pump will be to your liking.
PS. I am sick to death of the sound of mine.
itcanbesoeasy. Thank you for your clear advice. I think I'll go down this route.
Two pumps. One for hot and one for cold. If you try using a twin impellor the seals will go.
Reply to pump advice for a gravity fed system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Hi all, I have a combi boiler for hot water and heating but have 2 showers in the house. Obviously low water pressure if both showers are used at...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
Hi, I’m replacing my old Honeywell Smartfit system on a oil fired gravity-fed system in a bungalow. I’ve read conflicting advice on gravity fed...
