Discuss Pump problems in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Shaun,
How do I know what the "max pressure set" is? There is a pressure meter on the pump showing 2 bar (can be seen in photos above).
Cheers
Ok thanks very much I will try that.Turn the pump off elec wise and open a cold tap wait for the water to stop
Then get a pressure guage and there should be a shrader valve on the pressure tank read the pressure should be 1.8 bar if the pump is set to turn off at 2 bar etc
Reply to Pump problems in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
