Discuss pumping over problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
cdodds2004
Just after a bit of advice.
have a main 15he conventional boiler that at the point the pump switches off you get a trickle of water for about 2 seconds in the header tank.
F an E are in correct place with air jec but its about waist height in the airing cupboard. was going to combine the F and E, but wasn't quite sure why its doing it when pump stops.
Does the port valves shut at the same time ?
It has a 3 port so always open to something.
Just as a try leave 3 port on manual heating does it do it then
Could be the way it's piped tho how's vent,feed and pump piped ?
Could be a restriction in the airjec, they're prone to blocking up.
yea still does it. if you leave on heating and just interrupt the power!
yea was going to remove the airjec and combine the F and E
How high is the vent above the F&E tank? Could be a partial blockage in the airjec
Reply to pumping over problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to...
Hi, I have a stove pumping over into the f&e. The pump and thermostat both work and the system is free from sludge (very clear for an open vented...
Hi all, we have a water circulation pump to bring hot water from our woodburning stove and send it to a thermal accumulator tank. We've just...
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
1K
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
