Discuss Purging long gas supply in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
I have a job where I need to run 30 metres of 28 mm and 10 metres of 22mm copper tube. Now there is no gas hob in the place so I need to light the gas while purging. What right do you guys make up in this scenario. Cheers
+1 and what you feeding cant be much after 40m total
and a bunsen burner
sorry mutt, but i disagree!! probably wrong though!
whats the meter?
g4 i make it 0.04614m3
whats the meter?
g4 i make it 0.04401m3
So to calculate the installation volume it is G4 metre 0.008 + 30 metres 28 mm 0.0162 + 10 metres 22mm 0.0032 + 10 % for fittings is 0.0301?
Have I made a mistake some where
must be! 30mx28mm is 0.0387m3 & 10mx22mm is 0.01728m3 !!
according to the rays gas app...
30mx28mm + 10mx22mm not adding any fittings its 0.04401m3 or 0.04614m3 with fittings!!
think youve been hoping to do it in 10mm aint u? lol
must be!
you got a link to rays app?
Just done it manually and I make it 0.03014m3
30 x 0.00054 = 0.0162
10 x 0.00032 = 0.0032
meter = 0.008
total = 0.0274
10% = 0.00274
Total = 0.03014
Don't think I've missed anything?
30 x 0.00053 = 0.0162 + 10 x 0.00032 = 0.0194 (IVp) + 10% (IVf) = 0.02134 + 0.008 (IVm) = 0.02934 x 1.5 = 0.04401
If the pipe is feeding a boiler just turn it on. It will purge itself to a source of ignition.
with a wooosh!
Every app you use will prob give different answer.
If you want accuracy you need go old school and work out using your fingers and toes with standardised formula.
I got 0.02934 volume for a G4 meter.
Tamz, I was taught you only multiply x 1.5 of pipework is 35mm or over, or you have a U16 or bigger meter...
meter = 0.008
total = 0.0274
10% = 0.00274
Total = 0.03014
Almost right. :yes:
Went wrong by adding the meter before adding your 10%.
Technically if its a g4/U6 and pipework 28mm or under you don't need to bother working out the IV. The PV is 5 x cyclic volume (0.002) = 0.01
You've added 10% to the pipework before adding meter volume, right?
True, as that is minimum purge vol but I want to check whether I was taught wrong about the multiplying by 1.5?
Almost right. :yes:
Now that's a funny thing. When I first did ACS, I was taught to do your method. Subsequently I was taught to add meter volume first and then add 10%.
No its right enough.
You would only bother working out the IV for a purge if there was > 28mm or a G10/U16 on it so it is irrelevant in this case anyway.
Some acs centres have their heads up their rses.
Gimme a minute and i'll post a pic from UP1B.
Just checked the Construction Skills textbook. 10% added to pipework and then meter volume added. So yeah, the worksheet the assessment centre gave us was wrong!
Although, I noticed something else in the book - we've all been adding 0.008m3 as meter volume, but that is meter internal volume. Meter purge volume is given as 0.01m3 for U6/G4.
God, I'm sad...
Reply to Purging long gas supply in the Plumbing Jobs | The Job-board area at PlumbersForums.net
