- Messages
- 34,377
- Solutions
- 2
Anyone use it above ground ?
Discuss Qual oil pipe in the Oil and Solid Fuel Forum area at PlumbersForums.net
Not designed for above ground use I believe. Prone to UV damage.
Hmmm, sounds legitimate lol. I personally prefer copper, you know where you stand with it.
Where are you getting that info from? That I didn't know of to be honest. When sizing a fuel line it should be done through your OFTEC books, you'd be surprised at what sizes some lines can run off. The problem is manufacturers won't warrant an installation if you don't follow there sometimes ridiculous criteria. Will there be a tiger loop?
Quality pipe always a no no above ground. Only carry 10mm pvc coated copper. The copper is cheaper as well.
Reply to Qual oil pipe in the Oil and Solid Fuel Forum area at PlumbersForums.net
