Discuss Quick fix for a leaky toilet waste? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I've got a customer who wants me to fix a leak where the toilet pan meets the pan connector. Of course I'd usually take out the pan and replace the connector but for a variety of reasons (rusted screws etc...) it's difficult to move so I was wondering if there was a quick fix that would get him off my back as he's a bit of a pain. Thanks for any help you can give.
Hello Plumber,
I would just tell him its no point of fixing it temporary just because it will leak anyway sooner or later. If you are going to fix it temporary bare in mind he will call you back as soon as it starts leaking again even though you suggested him to replace the pan connector. if the bols are rusted and you cant get them of I would suggest him to get a new pan its better for him and for yourself.
a quick fix .. I have seen loads of different ways what plumbers do ... putty , silicon, bin bags, rags, towls, gorilla tape, bread,
a really good temporary fix I cant tell you best off to tell him you work with quality not quantity so he has to respect that you cannot fix something like that without changing the pan connector.
I hope it helped a little even though it was long
I have fixed quite a few toilet pan connectors just by doing same, - Tec7 or similar is excellent.
No point in touching a pan that is perhaps old and often rusty screws or tiled into floor, or on close coupled the cistern is a risk of all sorts of issues.
Life is just not worth the time wasted and risk. Customer will not thank you for making it into a big job, only to achieve the same result. Usually just the seal has weakened and not tight to pan spigot. Just shove a flat screwdriver blade into the joint and clean and dry it. Then keeping the screwdriver in the joint, just empty the silicone gun nozzle into the joint all the way around. No pressure on it really, so as good as new!
I used to just use ordinary silicone
My first private job as a 3 rd year apprentice was a leaky pan connector... boss gave me plumbers mate and said stick that around it ! done the job and got ÂŁ20... not proud of it but I was 18 lol
Never heard of CT1 before, it looks like a cure all sealant, got a get me some [DLMURL]http://www.ct1ltd.com/en/ct1-applications.html[/DLMURL]
CT 1 here as well, cracking stuff, once used you wont want to use anything else, saw a double butlers sink put in from the bottom just using it, the chap held it for about 3 minutes then let go and filled both up, I was amazed.
Reply to Quick fix for a leaky toilet waste? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern...
This maybe isn't so much about asking for advice as giving it 🤔 I had a leaking HW cylinder (23 years old) that I got fed up patching up with...
2K
Hi, I would love to get some expert thoughts on my pressure loss problem. I have just replaced my boiler and radiators to fix a raft of problems...
3K
Hello All- (Usual caveats apply: I am the rather unusual part-time variety of a GSRE, training self-funded and slowly trying to make my way and...
