Discuss Quick question about a central heating thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kmbrad
Hi all.
Firstly, I'm sorry if I'm posting in the wrong place.
I have just moved house and the gas radiator central heating system is some-what confusing me. I have an adjustable sunvic homewarm thermostat on the landing. If I turn it oneway I seem to get hot water and no heat to the radiators, and if I turn it the other way I seem to get slightly warm water and great radiator heat. Even with the boiler timer overridded this happens.
There is an analogue timer which you have to click in the pegs in the airin cupboard, and next to that theres a digi-timer. The whole set-up seems weird.
Any idea on the thermostat would be good. I have tried to google an image but its quite old and I can't find one. It has numbers 1 to 5 starting left to right, and yellow and orange arcs above the dial.
Regards
Karl
you boiler will have a zone moterised valve some where near the tank it is more than likley it is this that is sticking
Reply to Quick question about a central heating thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
G
I've just bought a 3-floor house with a gas boiler on the ground floor and hot water tank on the middle floor. When I switch on the hot water at...
