Discuss Quick question about boiler plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Davinder
As part of this boiler plus scheme, you can add 'smart controls' in order to comply.
now as i understand it, a heating system you can control from your phone is considered a smart control.
so....if you fit a hive wireless stat, along with the boiler your covered. Right?
Don't know about have as there's been some flip flopping you good your not etc but nest is 100% compliant
Can be fitted on both boilers Ronny , would favour this over a smart thermostat for a elderly customer or a landlords property . kop
Have Vaillant said that this stat can be fitted on their boilers as part of boiler plus now KOP? I was told a few months back it couldn’t
Reply to Quick question about boiler plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
