Discuss Quooker...is 110 degree water really ok? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So in simple terms there is the equivalent of a high pressure steam engine installed in a domestic kitchen , ok never in mine or my customers ever
I have read enough , just to peel a tomato ..seen it in tv huh !
This is a great place to learn and contribute thank you all let’s keep it up
A couple of posts seem to be mixing up absolute and gauge pressures.
The boiling point of water is 110°C at 1.4 bar (absolute) pressure. Most pressure gauges, PRVs, etc. on plumbing, and most plumbers, use 'gauge pressure', which is the pressure above the local atmospheric pressure, so they would indicate ca 0.4 bar..
FWIW, I've seen first hand some horrific burns caused by relatively small amounts of very hot (not even boiling) water, and these gadgets make me very uneasy.
NHBC position on boiling water taps:
Basically, if you have a Quooker, you won't get NHBC sign off without formal relaxion of G3 by the local authority. I have no idea if that could be got.
Reply to Quooker...is 110 degree water really ok? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
