Discuss radiator allen key in the Plumbing Jobs | The Job-board area at PlumbersForums.net
CXR100
anybody know of a radiator spanner, that had 2 joints in it, similar to the idea of a tap spanner, but had a tapered Allen key one end
Like this?
If not can you over tighten the union and use that to remove it?
no nothing like that, basically all it was was a piece of say 7 inch x 20mm round steel tube, and in one end you had a tapered allen key . that wound flop over 180 degree like the head of a tap spanner, you had something similar the other end, but cant remember what , I was an apprentice when last seen it.
It's the end from a rothenberger ratchet spanner.
[DLMURL]http://www.NoLinkingToThis/p/rothenberger-uni-spanner/[/DLMURL]
I've got one and although it's a bit pricey it does make life a lot easier.
Sorry, link didn't work. Try this:
http://m.NoLinkingToThis/details.htm?id=95088&csnbl=1
Mines a today's tools one just a cheapy one my rothy rusted up its just as good though.
I think I know the one you mean has a black plastic grab type key at one end can't remember where I've seen it possibly in Williams attached to a yellow piece card if I see it I'll make a note of it
Reply to radiator allen key in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have an oil delivery booked for Friday but we ran out earlier today. We topped the tank with 150L from containers, bled the first boiler from...
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
I’ve cleaned the grooves and tightened the grub screw at the bottom, but this tap handle (on the right of the photo) just won’t stay put. When...
M
If I dropped an Allen key down a drain, do I have to get it out? What happens if I don't will stuff just build up around it and eventually block...
The "boiler" in our house is upstairs. When the weather turned cold again, I switched it from hot water only to heating and hot water. After an...
