Discuss Radiator not working properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sam28
Hi Everyone
I recently had 2 new radiators installed in my house, one in the bedroom & one in the en-suite on the 2nd floor both with trv's (think thats what they are called) radiator in the bathroom works fine but the one in the bedroom begins to warm up then stops. Just wondering what might be the problem? Ive tried bleeding the faulty radiator but with no success.
Appreciate any help....
hopefully air lock, shut all other rads, dodgy rad should work fine.
then the "new" system will require balancing with the lockshield valves your installer should of done this, call him back
Reply to Radiator not working properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
When I turn on our CH there's a lot of noise from one specific part of the system - the pipes on the landing, and one radiator. It sounds like...
1K
I bought the a bleed valve from S****fix about a year ago: s****fix.com/p/radiator-vent-blanking-plug-nickel-2-pack/40972 It worked fine...
Hello all, I live in a flat that has communal heating through a single pipe system. I recently had replaced a deco flat panel (waffle) radiator...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
