Discuss Radiator Single Entry Point in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, can anyone tell me if this is possible, and if i would need to fit the internal 'lance' to a some sort of valve? Or do radiators come with the lance already installed?
Have a couple of single entry valves on my home system, been in for years. Work okay except one stopped for some reason, took valve out and found the 'lance' (injector pipe) had dropped off. Screwed back in and all okay again. Will be replacing with 'proper' connections when I upgrade the rads and fit TRVs. The injector pipe is about 9" long on a 3'6" rad and seems to get heat throughout the whole rad.
Reply to Radiator Single Entry Point in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What...
