swansea jack
We have taken over and restored the birthplace of Dylan Thomas.
A Vailant combi boiler was installed about 20 years ago. There is a 22mm flow and return which runs from the boiler in the ground floor outside loo (Ground and first floor plans at 5 Cwmdonkin Drive - Birthplace of Dylan Thomas, Self catering holidays and visitor attraction at Dylan Thomas birthplace of 5 Cwmdonkin Drive, Uplands, Swansea, Wales, UK) up to the first floor landing.
There is no air in the rads
I've turned all the upstairs ones off except the cylinder which appears has no isolating valves and it makes no difference. This would appear to rule out the pump as being the problem (the distance of longest pipe runs is probably about is probably about 22m).
Could the water be cycling through the cylinder and telling the boiler it is hot before the water gets to the farthest rads?
The room the boiler is in is small (1.5 x .9m) and gets very warm from boiler
Or something quite different?
Dylan would love a warm house!
Immediately above the boiler there is a rad tee'd off with 10mm pipes. Then there is a direct copper cylinder used as a rad tee'd off with 15mm pipes (Why? you will ask! Because Dylan talks about leaning against the airing cupboard to keep warm).Shortly after there are a number of manifolds which have 10mm pipes going to five rads on the ground floor and four rads on the first floor.
The rads in the first floor vary from very hot to fairly cool (the two in the front bedroom).
It is the same on the ground floor but in this case the two in the front room are very cool and do little to heat the room.
Domestic hot water is fine
I've tried turning all rads off except the cool ones and this makes no difference.The rads in the first floor vary from very hot to fairly cool (the two in the front bedroom).
