Discuss Rain Water Harvesting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kb76
In situations of pump failure within a tanked rain water harvest system (below ground) is there a way of filling via mains supply temporally ie via a filling link. As it stands the tank can be filled via a hose pipe but this is really only helpful when the emergency mains water solenoid has failed and won't fill the holding tank.
I understand rain water harvesting requires a catagory 5 air gap between mains water and the tank and cannot be connected directly. Is there another way to tap into the fed supply after the pump from the mains without breaking the cat 5 rule?
kevin
No.
There are 2 solutions;
Have a new spare pump available.
Have a twin pump setup with auto changeover /alarm.
I work on Commercial buildings, many of which now have RWH.
In most cases the Disabled W.C's are on mains only, as a back up.
Thanks. The system is feeding 6 holiday lodges each with 2 wc's. In one instance the pump failed which we replaced, however the 2nd time power was lost hence no water. I'm all for going green and RWH but when it fails it can cause a huge inconvenience. I'm surprised a suitable filling system/valve is not available these days to overcome these scenarios?
pump it back up into a cwsc in a roof and you have a reserve when the pump fails, you can then connect that cwsc upto the mains if need be via a cat 5 connector. only way to cover all angles
The problems come when the system doesn't use a high level storage tank and relies on the pump/s to provide pressure in the system and uses a low level break tank.
All the ones I see are like this.
True. They is no facility for additional tanks in this case. If you can imagine 6 single story lodges with rain water down pipes connected together below ground feeding a 1000gallon tank below ground level over 50m away. Then pumped back to the units, units have no loft space for back up so if power fails they've had it!
need to cough up for back up pump then no other easy choice
Back up generator or inverter to run the pump. Alternatively build a small water tower.
Unfortunately the system wasn't planned to well at the installation stage and additional back up storage is now not an option due to the site layout. We have 2 spare pumps on site now. Dragons Den opportunity here I feel...
Reply to Rain Water Harvesting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
For reasons that I won't go into. Is it possible to control the water flow to a cold water header tank without having a ballcock in the header tank? ie to place some sort of control elsewhere in the feed pipe before the water gets to the header tank - turning off the mains water supply would...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated house (4 bathrooms is tragic). Current set up is: A hot/cold mixer in the main ensuite which is ok as long as you don't run anything else. One electric...
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber is coming back in a day or so to make necessary repairs. I am a little concerned as the house has a Boilermate 2000 on the upper floor and the...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is unvented and pressurised. The cold water feed into this cylinder is from the attic tank, not the mains as I turned off the mains stopcock to see if hot...
