Discuss Ravenheat CSI 120 fault 28 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
elbistan
Hello everyone,
Just been called to this boiler with no heating or hot water. My first Ravenheat boiler. When there is demand for DHW boiler sees the demand the pump runs for several second and then the fault code 28 is displayed.
Looking at manual it states: Failed Flow Water Pressure Switch, or Pump.
I have removed the pressure switch and checked with a screw. There is continuity when slightly pressed with a screw. System pressure is 1.2 bars. Pump runs.
Will call customer service in the morning. Just wondered if anyone came accross this fault.
Merry Christmas and happy new year to everyone.
28 low water pressure switch. Try bridging out the low water pressure switch. Get a screwdriver or a bit of wire or take em off and hold them with long nose pliers or the like (the wires i mean) If it fires then it's a faulty switch. If not look at the pump. Is it easy to stop with a flat driver or does it kick out strongly?
Reply to Ravenheat CSI 120 fault 28 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring...
Hope someone can offer some help with this issue, I have a Baxi 105e works fine no real downside, serviced looked after regularly. Have an issue...
Conditions: nearly 10 year old boiler WB2B, heating mode off, DHW on or also in standby, Boiler shows no fault LED on, no new fault logged, room...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
