Discuss Rayburn 400K won't maintain temperature in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi - Our Rayburn 400K mainly runs low as a heater as we have LPG cooker. Yesterday (Christmas Day) I turned the control up to 8. It heated until the Thermodial needle got into the Roast sector, then it cut out and did not kick in again until it had cooled off - useless for roasting tatties! I tried switching off and on but no effect. The re-set button had not illuminated so presumably no problem with fuel supply. Possibly one of the thermostats is faulty? Any help appreciated.
If the burner did not lockout this suggests its not a problem with the burner or fuel supply. I more inclined to think a stat problem like you say but needs to be tested with a multimeter and someone who knows what they're doing.
Reply to Rayburn 400K won't maintain temperature in the Oil and Solid Fuel Forum area at PlumbersForums.net
  • Locked
I have learned a lot reading the forum and thought I should contribute back with my recent experience.I bought a 90 square meter 2 story row house...
2K
R
  • Locked
Hey all, apologies for the long post: I've had a new Ideal Vogue boiler installed with a T6 wired thermostat so the OpenTherm is activated as...
4K
richardc1983
R
A
  • Locked
Hi I see some of you knowledgeable people know about solid fuel boilers and hope you might be able to help me. I hada TRG80 installed in...
3K
Admiral allstar
A
A
  • Locked
I have an issue with a plumbed in mains pressure mixer shower. When running the shower the boiler will cycle to a very nice warm temperature...
11K
M
  • Locked
Hi, We've just moved into a new Barratt house. The water and central heating systems are very different to what were used to and I wonder if...
3K
MarkB
M
