Discuss Really loud noise when secondary... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Pump is running through Megaflow. Turn off the outlets and it is fine.
Find this on top of the cylinder, was this normal to put on top of cylinder? So the secondary return goes into the cold feed which taps into the top of this...
Yes the tmv3 is to reduce the temp but normally fitted at tap ends as temp can drop a bit
As for the pump should be hot out to cold inlet
Or like any other src hot to cylinder port
Got an email today saying that now I have replaced the SR pump, check valve and mixing valve from top of cylinder it is taking 3 minutes for hot water to get to the kitchen tap. Hmm
Is the pump on ?
Pumping in the right direction? Back to the cylinder
Pull it through? Not cleared up on that terminology. All I did was replace the pump.
Cheers Chris. Good to see the old boys still on the forum
Didn't change the pump valves ?
Soshould be still full need to check the pipe is warm if it isn't could be an air lock as chris says
Was there anything to stop the secondary return going back to the cylinder ?
Just thinking it is strange to have a blending (tempering) valve on the outlet of an un-vented as they should be controlled by the stats. If it has been fitted to actually reduce the temperature of the HW flow to the fittings then the return could have been taken back into the cold supply to the valve, otherwise the return water to the cylinder would cool its stored temperature causing it to reheated. This HW would then be drawn out of the flow only to be blended back down by the cold, if that make sense. Very poor design, my guess is the return goes through the valve no (or very little) back to the cylinder.
Hi Chris, below is a sketch up of the old set up before I removed the valve.
Not the best sketch but hopefully you get the just. I believe the return was basically feeding the valve.
No
This is how it is now. But I still for the life of me cannot think why this alteration would make it take longer to get to the kitchen. Surely the water would arrive at the tap at the same time as the flow and pressure are the sMe and the water is stored at 60
Problem is your pulling blended water round so it's cooler
Try putting a nrv just above the cold tee
So you've removed the tmv3 and capped the cold ?
In theory it should work is the pipework warm going to the pump ?
Yea normally set for hours that the place is in use with a boost / overrun
Very strange
Only thing I can suggest is remove pump and open the return leg to the cylinder does that get hot hot
If yes put a nrv where I said eg after the tee where the pump is on the cold pipe to the cylinder
Very strange
When you say remove pump and open return leg, do you mean open the pump valve and let water out and see if it is hot?
Yes checking there's no restriction/ blending valve passing back would be the same temp as the water going out of the cylinder after the leg is clear of any cold / lower temp water etc
Valve shut ?
Reply to Really loud noise when secondary... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
