Discuss Recommendations to replace this in landlord property in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi everyone
Another post from myself to add to the list if not a problem.
What would you be replacing this with in a landlord property? He's not too bad, doesn't want to penny pinch and put in the cheapest rubbish available but wants reliability and not be ripped off. What would you go for?
Reactions: Dan
Baxi 412 or 418 depending on Kw required + an ifos for boiler plus. No need to change time & temp controls with the ifos.
Don’t need to comply with boiler plus on a heat only boiler yet
Quite right Shaun, not mandatory 'yet' for heat only. No harm in future proofing heat only swaps though for the sake of £35.
Depends how easy it is to get to an outside wall
How do you mean? The Ifos, (In Flue Outdoor Sensor) just clips to the flue terminal and the wire is run through the flu air intake, straight into the boiler.
I was thinking wc sensor also that effects hot water aswell so can have a problem with legionnaires as it won’t get upto temp
Reply to Recommendations to replace this in landlord property in the Plumbing Jobs | The Job-board area at PlumbersForums.net
