Discuss Remeha avanta plus 28c, hot water but no heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
3083sam
Hi
Ive been called to look at a remeha avanta plus 28c with hot water working fine just no heating. No fault codes are showing up at all. Is there anyway of checking the motorised valve or the divertor as im not that familiar with these boilers apart from having to change the seals and ignition electrode
Thanks, Sam
Not without getting yourself into the private forum.
Please send an image of your gsr card to [email protected].
We'll check it then give you access to the gsr private forum
Reply to Remeha avanta plus 28c, hot water but no heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
