Discuss Remove lead pipe overflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
GC2
How do I go about removing the lead pipe from this cast iron bath overflow? Nothing seems keen to move!
Do you need the pipe afterwards?
Use an angle grinder to grind the back off
Good luck with the taps
Two ways hacksaw but very time consuming
Or alot of heat on the back of the fitting (where the flats / nut shape is) e.g. Blow torch
And undo from the front the front grill has female threads in it
It tends to be the putty used to seal it which causes it to be mega tight to undo. Like above. When I come across this situation I use a little heat and undo from the front. Always worked for me. Good luck.
Might give it a go with the blow torch and if that fails angle grinder it.
Thanks again
Going to give this a go. What's the best tool to use to undo the grill from the front?
Cheers
Strap wrench but you have to be careful due to the heat
Any luck ?
Reply to Remove lead pipe overflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
