Discuss Removing a stubborn tap valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Annnie
Hi folks
I'm trying to remove the valves of my bath mixer taps (they are against the wall). I've tried various DIY spanners, pliers, WD40 etc but it just wont budge.
So are there any tricks or special tools for getting the valve out?
Sorry photo is sideways :)
Thanks Tonycane but it just slips off. Its not 'rounded' but its just not budging.:disappointed:
16mm then if that won't fit try an imperial/ adjustable movie
Reply to Removing a stubborn tap valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm...
I’m trying to replace a cartridge on a Grohe mixer tap but I can’t get beyond second stage! I have removed the grub screw,but cannot lift off the...
2K
I am trying to replace the cartridge for a waterfall tap (mixer mono) for the bathroom sink, I have run into a problem whereby I cannot remove the...
Hi all, trying to replace a Victorian mixer tap head for bath as old one getting stiff. I've got cap off and taken screw out however can't remove...
1K
Hi All, I have this monobloc basin mixer tap in my bathroom. It was installed 11 years ago, but the hot valve has started to drip from the top...
1K
