Discuss REMOVING A TOWEL RAIL in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi , I’ve just bought a house and there’s a big towelrail on one of the radiators, it looks really ugly and no use to me , I want to remove it and wanted to ask if it is ok to remove the towelrail and put blank cups on ? Would it affect anything else with heating?
Any pictures of the towel rail ?
I’m adding pictures, hope it helps
Yep close the valves and then some 1/2 brass caps once the towel rail has been removed
don t forget to turn the rad off first at the base, then turn towel rad off, there will be water from the rad remmember still under presure so be awhere of that .
Reply to REMOVING A TOWEL RAIL in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
PSxxxxxx
