Currently reading:
Removing Cylinder Foam
Discuss Removing Cylinder Foam in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Crimelord
I have a few hot water cylinders just wondering if there is any tips for getting the foam removed from them !!
I use a blunted wood chisel and a floorboard chisel, get in behind it and pull it off. Parental supervision is advised though !
sledge hammer takes 5 minutes,btw your scrappy will pay less for a foam cylinder has they have to remove it
Mine doesnt give as much if there coated in foam, he likes em bare back !
Well I'll count myself lucky that my scrappy is such a decent bloke. Even if they always look miserable when you turn up with scrap for them. (Never understood that).
Most will deduct a kilo from the weight for insulation.
If you have the time cut the threads off it with an angle grinder (just cut a square). then stick it in with the copper for a couple of quid more.
went to see my best friend to me ,but not so much to tax man !!!
2 cylinders and few bags of scrap -800 :)
did not bother separating all on the scale £4 -1kilo
I slice the foam vertically with a sharp blade then scrape it off with a chisel - it'll come apart a bit like tangerine segments.
My scrappie gives a lot more for de-foamed cylinders with the tops cut off and all the scale emptied out.
took down two cylinders other day foam and brass removed got £110, he told me with foam half price . easiest way to remove foam is to t
beat it like your apprentice
Mr TP says just leave the foam on.
He has also forced me to drink too much wine (so sorry for tyos) annd he told me this story:
in 19992 on a Lang building site (I can't tell you know more to protect the guilty).
A New plumber started on 2nd fix Mr TP showed him the site and said they meet at lunch time in plot 42 if he wanted a break or he could carry on working.
New plumber said he hadn't worked on new build site for a long time. Mr TP assured him that 2 second fixes a week were possible once he had a routine.
At lunch Mr TP dropped by to the new guy, to see how he was getting on.
New Guy, " I haven't got much done."
Why?
New Guy, "It has taken all morning to get the packing of the cylinder."
Mr TP? "What Packing?"
New Guy, "The Yellow stufff."
Mr TP laughed, " I like your sense of humour, we are going to get on."
No kidding.
Mr TP went with him and half the insulation off the cylinder had been stripped.
Mr TP
Really!
This is so funny we are laughing now.
Mr TP went and told all the p;umbers at lunch and they thought he was joking!
All cylinder s had foam insulation for about 7 years by this time but Mr TP and I are old enough to remember days when the copper cylinders were bare!
use a spade to get the insulation off, so much quicker and easier. My local scrappy gives £15 for a normal cylinder with insulation and scale and £65 if its cleaned.
Reply to Removing Cylinder Foam in the Plumbing Jobs | The Job-board area at PlumbersForums.net
