Discuss Removing disused boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
My mum has moved into a new place. Despite a combi fitted in bathroom the previous boiler was left on the wall in the kitchen.
The gas supply pipe to the boiler has been cut and capped, as have the flow and return. The two 15mm pipes running from above are nothing to do with/not connected to boiler.
The only thing I don't know is whether the electric is still live to it and I am not knowledgable enough to check.
If I get a spark to confirm there is no power to boiler is this something I could remove on my own? I am not gas safe and am only experienced in small wet plumbing maintenance type work.
If the very act of taking off the wall requires testing gas supply as a matter of course I would not be competent to do this
I'm guessing it weighs a lot but was hoping I might be able to manage it.
From looking behind it it looks like I may need to take cover off boiler to get at the fixings that secure it to wall?
To make matters trickier, access to where flue goes through wall is - from the outside - extremely limited.
If this is more of a two man job for a gas safe engineer I will get someone in to do it.
You can do it as it's not live
Weight wise about 30kgs
And yes just work methodological
Sounds like the old boiler has been decommissioned and therefore it is not part of the gas installation anymore. So you can freely do as you please to it without breaking any laws. The boiler is heavy but you should be ok on your own if you are fit and able bodied. It wont take you long if all the pipes are already capped off and the flue will simply knock out from the inside once the boiler is off the wall.
Has the boiler been left there for a reason? Other then bad access to the flue or have these boilers got A/C materials inside them?
No your fine old gloworm space saver I think
Many thanks for the info everyone.
But how can I know if it's not connected/live electrically? Shouldn't I test it somehow? I have no tools/experience for doing this.
Obviously I'm presuming it won't be as they went to the trouble of disconnecting gas and pipework but don't want to work on assumptions really. I suppose I could always get a spark to confirm.
If you do not have the tools or confidence to check for live power then yes get a sparks to check it for you. (Safest option)
Do you have a multi meter?
Thanks.
Also am I right in thinking you need to take off front panel of boiler to get to fixings?
I've helped hang a few boilers many years ago but they all just lifted onto a jig from memory. This one looks bolted on.
Thanks.
Yes slide the brown cover towards you and off it comes
Two screws there and two optop op the boiler on tabs
Normally about 4 fixings and the flue will hold it sort of so will need a wiggle/ cursing to get it off weight isn't bad but top heavy
Reply to Removing disused boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not getting through to the boiler. The...
