Discuss removing HEP 2.0 smart sleeve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all
how do you remove these smart sleeve inserts from an HEP 2.0 pipe
thanks
Not really reusable but I have removed em with a pair of grips but it will score the pipe inside so the pipe will need cutting back ?
thanks, i suppose if you were cutting pipes short, it would matter anyway. i was thinking if i cut the pipe, slit it open long ways, could i re-use it? its only 48p in toolstation, but i'd save the time from going to TS to pick them up
Reply to removing HEP 2.0 smart sleeve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
