Discuss Repair or Replace Recommendation? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
20130405_170548.jpg!Hi, am hoping someone can advise on whether I should repair, or replace, my Glow Worm Economy Plus 50F conventional boiler?
I am not requesting technical advice on how to do this - merely a basic recommendation from a professional as to whether it's worth repairing my boiler.
(Croppie has accepted this proposal - as I'm not actually asking anyone to tell me how to do this myself).
Currently the boiler is not working - I have had an engineer check it over - so took some photos at the same time.
The fault is possibly due to insufficient airflow through the heat exchanger: when you switch it on, the piezo igniter just keeps clicking but you don't actually get ignition. The fan is working. When you remove the 2 exterior covers, so that the gas jets are exposed, and then switch it on it ignites immediately: the GSR showed this to me when on-site.
I have attached a pic of the heat exchanger - which looks pretty clogged to me - so seems a reasonable assumption that no air is being drawn through it - and hence no combustion.
I'm no expert, but the GSR did quote for repair £1000 and replacement £2700.....this seems expensive to me for a 15kWh boiler that only has to run 2 sinks, one bath and 5 rads.
So, bearing in mind the photos - do you think this heat exchanger really is 'toast'? i.e is it worth me bothering with a repair - or should I just get some more quotes for replacement?
Any help anyone can give would be much appreciated.
Pretty much but always worth getting a couple more opinions at that level of expenditure.
Is it kettling badly?
Are there any leaks on the exchanger?
Is it costing a fortune to run?
If no to all these clean it out and see how she goes
That's what I wondered about - having someone to clean it up - at least that way I could get a bit of extra time to get some more quotes in without freezing my bits off... :)
When the case was open, I couldn't see any leaks - and no it isn't costing a fortune to run. Not sure what you mean by 'kettling' though.
The other issue is, that so far, no one has wanted to bother cleaning it...at £100 per hour, I'm not overly keen on getting more engineers to check it over either.
Wish I could charge £100 per hour :-(
Whereabouts are you? £100 an hour is a bit steep. There may be someone from here that can have a look at it for you. I'd certainly be looking a bit further at the problem before going for a new boiler.
Thanks - that's what I thought, so far have tried 5 firms and all are charging in the region of £85 - £95 pph + VAT...so £102 per hour min.
Reckon I will spend more time looking for a more reasonable rate - but here in High Wycombe (Buckinghamshire) all the trades (except mine! - I solve peoples IT issues), seem to have high charges.
Reply to Repair or Replace Recommendation? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
