Discuss Replacement circulating pump advice please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Help please !
My central heating system is very basic and consists of a boiler, circulating pump, basic timer/programmer and piped installation. The circulating pump is on its last legs and I intend replacing it.
Details on the existing pump are:-
Two Speed Grundfos Super 4
No - F804 Type - UPS 18.45 Class F r/min - 2500 44W 220V 4uF
I am looking on the Screwfix (very local to me) website for a replacement pump and they have the following one in stock which physically fits in between the pipe connections:-
Grundfos UPS2 15-50/60 Central Heating Pump
Product Code: 42635
Suitable for working temperatures up to 95°C. 1½" BSP connection. IP42 rated.
•3 Speed Settings
•ERP Compliant
•2 Year Manufacturer's Guarantee
•6m Max. Delivery Head
•1½" BSP Connection
•2°C to 95°C Max. Temperature Range
•3m³/h Q Max. Flow Volume
•IP42 Rated
Specifications:
240V. 50/60Hz. 130mm port to port. Max. temp. range: +2°C to +95°C. Weight 2.65kg.
£119.99
INC.
VAT
Would you be able to tell me if this is a suitable replacement when comparing specifications please ?
Any response will be much appreciated
Len
hi len qelcome to the forums yes that pump will do you grand.
Hi there lenc and welcome to the forum.
Get the wilo one. U get 5 years warranty on it. Grunny u get 24 hours
Whereas Wilo likely to last only 24 hours but Grunny 5 years !!!!:wink_smile:
Only joking Grundfos gone right down in my estimations in the last few years they only want to draw pictures or refer you to a web site not answer me questions.
Reply to Replacement circulating pump advice please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm. This question is for my own house setup. We are really fortunate to have a large house, about 5,000sqft in total over 3 floors. It was built around...
I want to replace the three 11 year old Grundfos UPS 15-60 130 pumps as a part of trying to reduce the electricity consumption of my heating/DHW system. The pumps circulate the water in i) the UFH, ii) the first floor rads and iii) the mains pressure DHW cylinder primary circuit. The Grundfos...
6K
Jojomacjo
J
As mentioned in my 'System Drain' thread the house has been extended in 1986. In recent years I felt the circulation was not as good as it should be . I have previously replaced a section of pipe when we had blockage at point where cold feed joins together with clean and drain, refill+...
2K
H
HRP123
H
