R
realnovice43
Hope you can help me with a novice query - the current trap sits in a cut-out in the floor under the bath - so water can run directly onto the ceiling below and it did!. No matter what I do it's weeping from the thread on the connection to the waste.
I think it was cross-threaded at some time as it has been stuck on to the old waste with mastic so I want to replace it.
Waste pipe connects directly to the stack. The trap connects to the waste pipe by screwing onto a small piece which then connects to a push fit bend.
The local plumbers merchant told me the old trap was a P trap which was the wrong sort for a bath and sold me a McAlpine shallow trap which I now know has a 19mm seal that's too low. I see posts about 50mm or 75mm being the minimum and I'm not sure which I need.
Which of these is the correct way to go please?
1½" x 50mm Seal Bath Trap - Bath Traps - Traps | McAlpine Plumbing Products
1½" x 75mm Seal Bath Trap - Bath Traps - Traps | McAlpine Plumbing Products
