Discuss Replacing a Rayburn BM30 Oil Valve with a Toby Valve. in the Oil and Solid Fuel Forum area at PlumbersForums.net
I am told that a Toby 4cc-13cc oil control valve can be used to replace my Rayburn’s faulty obsolete BM30 4cc-13cc oil control valve.
Will the Toby fit directly in place of the BM30 on the same mounting bracket on the side of the Rayburn, and are the Toby’s inlet and outlet connections in line with those of the BM30?
It will fit into the same bracket however you will need to reset the cold oil depth in the burner along with the flow rates.
Are you an engineer or homeowner? If the latter I would get someone in. These atmospheric burners are simple enough in principle but require someone with experience to set up. It's most likely minimum and high flow rates will need adjusting after a few days to find the burners sweet spot.
Reply to Replacing a Rayburn BM30 Oil Valve with a Toby Valve. in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
