Discuss Replacing towel warmer with designer radiator that can still hang towels on. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Customer has asked for a towel warmer to be replaced, they want a designer radiator, anthracite colour, and still be able to hang towels on it. the wall space is limited. 400mm wide rad is the max it will take, preferably with bottom entry straight valves. Between 1200-1400 height.
I cant find anything, anyone able to help?
No worries mate, I still see the same customer and they say the towels dry much better on the hooks anyway
These any good DQ Heating fitted a couple aluminium powder coated . Kop
Just mentioning...
Check the Ts & Cs of these rads regarding hanging damp towels.
Yes, we all know that's what they are for, but all ali or steel (not stainless) rads T&C I've read specifically state they NOT for wet/damp towels. They are for WARMING dry towels.
Just make sure in your supply contract you point that out so when in 18 mths time they come back to you cos its a rusted hulk you're covered.
Thanks KoP, they look good, I will see if there is a suitable size. I have found a couple of others so will send pics to the customer later.
YorkshireDave good points thanks. Will make sure customer is aware.
Reply to Replacing towel warmer with designer radiator that can still hang towels on. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
5K
  • Locked
I currently have a towel rail plumbed into the central heating system in my bathroom; I want to replace it with a radiator and preferably without...
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
A number of issues have been raised from a boiler replacement. Boiler not operating and with no pressure. Tile damage Sprawling pipe layout in...
5K
C
7K
ecowarm
E
