  • Thread starter Old Account
  • Start date
  • Replies 40
  • Views 297
Discuss RIDDOR....... sooo sadddd in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hi lads
I would need your help for a second as I would like to report a job I have seen today.
Is there any email address to HSE as I would like to attach my picture.
See below
Kind regards,
Ron
Good training subject
What makes it unsafe and why
Also what's reportable about it (eg riddor)
Nowt wrong with an open fireplace. :D
I don’t think it’s very safe when it back ups into the living room neither proper installed. For me it’s shocking and putting his family at risk.
Do you think it’s correct when fumes backing up into the room?
Is that not shocking for you ?
I always was under the impression you take th8ngs very serious :)
If I am wrong that’s ok but have reported it just to be on the safe side.
What about spillage everywhere ?
It hasn’t got any hearth which is non combustible, what about flue ? Haven’t seen any flue liner either and I was sure you will require a flue liner. What about the safety surrounding what happens when the coal is coming out onto wooden floor?
You don't need a liner as long as the chimney is sound.
Looks like a work in progress.
that’s actually true. But how do I know it’s sound? If he uses a fire like this I wouldn’t trust his words. However, for me it ain’t right based on spillage etc
I've reported things in the past HSE not interested just wanted to know the in & outs of a cats Arse , So to be honest I cant be bothered anymore !!
That’s not correct. If they run such a company they should undertake some actions. However, I wanted to back up myself and that’s what I did.
Thanks a lot to all of you for your input
they can only do something if a company has done something
if the customer has done it themselves they dont care
That looks like its been there for years, has it just been installed ?
I can’t tell you that. I assume it’s like this for some time. However, it’s not safe to use and that’s for me the priority.
Its my understanding that HSE like to collect information and build up a file on the offending person Don't think much gets done for a one off reports, unless something serious has happened , Explosion etc.
Yes, and they will ask if your competent to judge Solid fuel installations, i.e. are you qualified ?
There can’t be decent chimney draw on that fire with the wide and unclosed opening. Fumes at times must be terrible in that room.
The hearth base seems to be concrete, so probably as safe as if a proper hearth was in place.
Definitely a laid back homeowner there!
I am not. And I do not need to be qualified to tell that this is a dangerous install / or whatever you call it. You can see it has spillage marks all over the place. Even if they asked I’d be very frank that i am not holding license but still able to judge.
wrong
how do you know its spilling fyi coal is a dirty fuel
But how do you know that it is not safe Ron?
Spillage would be my first point. If you’d entered the property you would have smelled wrong burning or something like backing up into the room. It was very intense smell of wrong burned fuel. However, even though I am a bit more sensitive than others but never seen something like this before.
:D thats the first time ive know anyone be able to smell spillage
my suggestion to you leave it alone dont do anything
The draw from the chimney will have a route to take air direct from room and won’t draw the fire always properly, - like when a door is opened for example.
So definitely will be fumes at times, but tbh that is normal with any properly installed open fire. Also normal to get some sooting.
Have I ever mentioned that I can smell spillage? I said that I entered the property and it smelled of wrong burning fuel like black soot.
thats a coal fire for you :D
Well depending on how long you have been doing this job, you could see more and worse, I've seen things that would make your hair go white, B4 CORGI and the need to report everything, and still come across some very bad sights ,
That’s true. As I said for me it was the first time I ever came across this sort of diy fire. I trust your experience as a qualified gsr... I believe you’ve seen a lot of bad things in your career and perhaps still
I now ignore a lot of things I see.
Unless I am asked to touch the offending work, or there is high risk, like live wires, or flue gases danger, then most I do is just advise the customer to have the work brought up to a safer standard.
You can't force a person to have things made safe, except on gas work, as far as I know
Did you see that Best? Did I see what Harvest? Exactly Best.;);):p:p:D
Reply to RIDDOR....... sooo sadddd in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am looking to join a plumbing and heating engineer 4 days a week whilst I attend College to gain my level 3 plumbing and heating qualifications. if...
Billy Barnard
Hi all I need to run this CH pipework to a radiator located beyond the electric wiring in the image below. Just to be safe I was wondering if there are any rules / distances, etc I need to be following when avoiding the wiring? Many thanks. P
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
