Discuss Rolyat Cheltenham Combination Unit in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
OK thanks. Not sure about that. It has main switch and a booster switch. Booster switch is never used though.3kw if only one immersion
Draws 3kW only when heating. May take -wild guess - 2 or 3 hours to heat the tank from cold, and then the thermostat switches it off until the temp drops through usage or heat loss. So one up to temperature the average consumption is much lower than 3kW (depending on usage)Thanks @Basher
I spoke to them. They confirmed it is 3kw as ShaunCorbs said earlier.
Does this mean it draws 3kw per hour when on?
Looking at the Mcdonald data suggests the loss from the cylinder in 24 hours is just a bit over 1kW. So once heated up, say about 30p a day to keep the tank full of hot water. (assuming average day-rate for electricity now - eg £0.27 per unit?Ah OK. That's clear now. Thanks very much.
Reply to Rolyat Cheltenham Combination Unit in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
