Discuss Rough toilet pan outlet? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Dee Eye Why
Hey all. I'm installing a new toilet (Bunnings special...) in my ensuite.
I seemingly had it all connected properly, but when I was testing for leaks by flushing over and over it started leaking.. It seems like it's leaking where the rubber vario bend seal goes over the china toilet pan outlet (best I can tell?).
The china outlet pipe does seem kind of rough, nowhere near as smooth as the PVC on the other end of the vario bend that goes into the sewage pipe seal in the floor. Could this be the root cause? Is there anything I can do to fix it?
Thanks in advance
It’s possile the roughness is causing the leak. Can’t say I’ve ever come across that as an issue.
Perhaps the seal is damaged or not pushed on enough. Could try rotating the seal 180 degree.
The vario could be at a slight uphill angle stressing the seal?
What type of toilet? Close couple with tank sitting on top? You sure it’s not leaking from above and landing on vario?
Reply to Rough toilet pan outlet? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
