Discuss Rugby Club Changing Room Showers in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
My local rugby club are having intermittent pressure drop problems with their showers. I’ve done quite a lot of domestic plumbing but need advice on this. The system is set up with 4 large hot water storage tanks, there are 4 pumps each which have a flow sensors on them. There are 10 showers each for home and away. I think 2 tanks and 2 pumps service each set up of 10 shower heads. Each shower is operated with non concussive button valves. I’ve noticed that when the pressure is low when all 10 showers are activated, sometimes only 1 pump runs. Could it be a flow sensor problem? If so how can these be checked? It’s the type which is clamped around the outside of the outlet pipe from the pump
Tbh wrong set up best to rip out and start again either with one pump per shower or boost the pressure into and install unvented s or direct
Are we talking regular shower boosters here?
Would be weird to have them paired up so 4 pumps 4 sections 4 blending valves would be where I'd be looking on this one.
Those flow sensors are activated by a magnet 'floating' in the pipe so you can disconnect and move to operate but only really proves that pump works.
You can have them stick or get stiff but it's likely here that they are being held back by the pressure from the other pump
Reply to Rugby Club Changing Room Showers in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains...
Max Hill
M
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
