Discuss S Plan Vent Feed Options in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Please see attached diagrams.Please let me know what you think.
any reason 28mm?
and 1
It's the size of the pipes (Flow and Return) on a Greenstar FS 30CDi.
fair enough you do realize you cant install a boiler unless your gas safe?
I'd guess it's an old house, pipes underf floor & minimising the risk of creating leaks?
The tank fed should be okay as longs it's all cleansed correctly, plenty of inhibitor & check there's no pumping over etc into the tank!
Go with 1. Ideally, you want the cold feed to dip under and connect into the bottom of the pipe to stop possible gravitation into the tank.
Why not just read installation manual ?? Page 9 will answer all your questions regarding position of pipes Vent & Cold Feed in relation to type of system you are fitting,
Reply to S Plan Vent Feed Options in the Plumbing Jobs | The Job-board area at PlumbersForums.net
