Discuss SALUS RT300RF WIRELESS THERMOSTAT PROBLEMS! HELPP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ok so I moved my boiler upstairs it's all working fine for hot water but can't get heating to work I have a wireless thermostat connected but it's not bringing the heating on and it's got me thinking I've not wired it in correctly, I have 2 cables coming from the bottom of the boiler, 1 is the mains plug for the boiler and the other is for the thermostat it's just a 3 core flex cable and I have wired it in to the receiver live to live neutral to neutral and I have cut off the earth, it then says to put a link wire between COM and live which I have and then got the thermostat and called for heat, 3 seconds later the green light clicks on (calling for heat) but there is no life from boiler, have I done something wrong??
who moved the boiler?
My advice would be is to get the gas safe engy who installed your boiler back to wire the stat in as you need to be gas safe registered to remove the cover to the boiler
Reply to SALUS RT300RF WIRELESS THERMOSTAT PROBLEMS! HELPP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
Hi I'm having issues with my wireless Honeywell thermostat. It's sat in the living room, set at 18C currently. It makes my Worcester Greenstar 18Ri to short cycle. So, the moment it gets cold outside my boiler works for about a minute, then stops, and starts again in about 5 minutes, then...
2K
Hi, I live in a really remote part of the Highlands, so paying for a plumber (or electrician?) to do this will be brutally expensive, so I need to do it myself. I have a Grant Combi 26e boiler. I'm replacing the old thermostat with a new one. Although the boiler is a combi, I think the old...
I've recently replaced an immersion heater for a direct cylinder, for 2.75-3kW. The new one seemed to be working a week before I got a callback. I checked the resistance of the immersion heater, and it read 19ohms, and the voltage on the live and neutral read 230V, but there was no humming or...
Hi I’m looking to install the above. Atm I have an older one fitted (old wireless thermostat and old receiver that’s wired into my combi boiler. Pic below shows how my current one is wired, live neutral and would the 2x black wires be switch wires and would matter what way they were wired in? My...
