Discuss Sani Split not working properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Heathern93
Hello, I have a Sani split in my house and it is not working as it should. When I flush the toilet, the sani split makes a loud humming noise as if the motor is running but the blades are not turning. The bowl empties very slowly and after 10 minutes or so it gives up and leaves the bowl half full. The strangest thing is that after about half an hour, it kicks back in, working perfectly and clears the bowl, bit then if you flush the toilet again it goes back to the strange humming sound mentioned earlier. My main problem is here I do not know who to call as it may be a loose connection somewhere and I don't know whether a plumber will fix issues to do with wiring and I will waste money on a call out when I need an electrician. The other problem is that either the previous owners of my house or my landlord have grouted the sani split into the floor tiles, so I cannot split it apart myself even if I wanted to.
Thank you in advance for any help
We have a sani expert here but please register with the forum and repost.
Reply to Sani Split not working properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
