Discuss Saunier duval smart thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Booth01
Hi I am looking for a smart thermostat but don't know which will fit
I went on nest web site and said check wires for codes but won't fit
as seem to only have 1234 in circuit board just seeing if any one has fitting one
to these boilers
thanks
to these boilers
thanks
what model saunier duval?
Semia condens F24
you should have a white external controls lead to connect external controls to. This connection is a volt free/ potential free contact that acts as a switch you must not apply any voltage to this connection.
Edit: The nest heat link relay is compatible with this method. In their manual they refer to it as a "dry contact".
Thanks yes got a white lead hanging down I will look for a nest one
most thermostats will be compatible you just have to make sure you install it correctly as not to apply voltage to the external controls connection within boiler.
A few other options would be netatmo, owl, salus it500, hive, heatmiser neo, tado, etc
Ok thanks looking at a Honeywell
Reply to Saunier duval smart thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
