Discuss Sealed system grabbing air in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
Any ideas why a sealed system with a combi could be grabbing air. The upstairs rads have air in and the system reads 3 bar cold. When the air is bleed out the system returns to 1 bar or less. It's an ideal instinct boiler basically a logic.
You sure it’s not hydrogen ?
Active corrosion. Has there been any recent work on the system, new radiators / pipework, etc.? Check the pH and inhibitor level in the CH water.
I could bleed and test with a lighter? I wondered if you'd be anything to do with the expansion vessel. It's happened to quiet a few houses on this new build estate as said around 6 years all
Reply to Sealed system grabbing air in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
PSxxxxxx
